CSNAPC-12164: Oracle mount/unmount/catalog/uncatalog REST APIs fail with 404 on 6.2.1 and 6.2.2 — route parameter {name} wrongly validated as a host name
Issue
- Oracle mount/unmount/catalog/uncatalog REST APIs fail with 404 on 6.2.1 and 6.2.2 — route parameter \{name} wrongly validated as a host name
- In SnapCenter 6.2.1 and 6.2.2, Oracle RAC/ASM backup mount operations submitted through the following REST API fail with HTTP 404:
POST /api/6.1/backups/SCO/{backup}/mount - The response is returned as a bare \{}404 Not Found{} with an empty body, even when the backup, target host, ASM configuration, and resource are valid.
- No job is created, and no corresponding entry is written to the job logs. This makes the issue appear to be a missing-backup problem, although the backup can be verified through other REST APIs.
The same operation succeeds through:
- SnapCenter GUI
- `New-SmMountBackup` PowerShell cmdlet
- The clone workflow:
- `POST /plugins/SCO/resources/clonespecification`
- `POST /plugins/SCO/resources/clone`
