NetApp Knowledge Base
Unable to add H615C nodes to H410C cluster with VSS and 6-cable
157
Visibility:
Votes:
0
Category:
netapp-hci
Specialty:
hci
Last Updated:
Applies to
  • NetApp HCI
  • NetApp H410C node
  • NetApp H615C compute node
  • NetApp Element software 12.3
  • VMware Virtual Standard Switch (VSS)
Issue
  • Unable to add 2-cable H615C nodes to existing 6-cable VSS H410C cluster
  • Error message: The installation's current network configuration does not have VLAN IDs assigned. To create a new cluster using the 2 cable option, you must re-network the current network with VLAN IDs
New to NetApp?
