NetApp Knowledge Base
How to recover from setup-mnode failures
2,197
Visibility:
Votes:
9
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
NetApp Element software 11.3 and above
  • AFA customers need to run the /sf/packages/mnode/setup-mnode script to configure and get docker services running
  • If the script fails, the next attempt may result in an error: docker_gwbridge already exists
  • This article describes how to recover from such setup-mnode failures and perform a cleanup before re-running the script
  • Procedure can also be followed when faced with mNode connectivity issues to the NetApp Element cluster
New to NetApp?
