NetApp Knowledge Base
Unable to re-initialize system with ADP
1,365
Visibility:
Votes:
0
Category:
aff-series
Specialty:
HW
Last Updated:
Applies to
  • AFF-A220
  • OS 9.8P2
  • Advanced Drive Partitioning (ADP)
  • High-availability (HA) pair
Issue
WARNING
This menu option erases ALL data on the disks of the node and HA partner when partitions are shared between node and HA partner as well resets your node configuration to the factory default settings.
  • Disk assignment fails after options 9a/9b
***OS2SP configured successfully***Jan 18 16:11:25 [localhost:cf.ic.sbb:notice]: HA interconnect: SBB Compatibility Event. Compatible partner node found. The interconnect device has been enabled.
Jan 18 16:11:38 [localhost:discover.6500.unsupported:notice]: FC-to-SAS bridge ATTO 6500N discovery is disabled.
pnso provider init started.
pnso init failed in pnso_init() : 35
hwo: Node is using hardware provider : 1.
cryptomod_fips: Executing Crypto FIPS Self Tests.
cryptomod_fips: Crypto FIPS self-test: 'CPU COMPATIBILITY' passed.
cryptomod_fips: Crypto FIPS self-test: 'AES-128 ECB, AES-256 ECB' passed.
cryptomod_fips: Crypto FIPS self-test: 'AES-128 CBC, AES-256 CBC' passed.
cryptomod_fips: Crypto FIPS self-test: 'AES-128 GCM, AES-256 GCM' passed.
cryptomod_fips: Crypto FIPS self-test: 'AES-128 CCM' passed.
cryptomod_fips: Crypto FIPS self-test: 'CTR_DRBG' passed.
cryptomod_fips: Crypto FIPS self-test: 'KDF' passed.
cryptomod_fips: Crypto FIPS self-test: 'SHA1, SHA256, SHA512' passed.
cryptomod_fips: Crypto FIPS self-test: 'HMAC-SHA1, HMAC-SHA256, HMAC-SHA512' passed.
cryptomod_fips: Crypto FIPS self-test: 'PBKDF2' passed.
cryptomod_fips: Crypto FIPS self-test: 'Self-integrity' passed.
HA Config: Chassis = non-ha Controller = non-ha
WARNING: 0 disks found!
  • When using option #4 from boot menu the system reboot with no disks attached error message:
WARNING: there do not appear to be any disks attached to the system.
No root volume found.
Rebooting... (press ctrl-c during boot to break reboot loop)
Uptime: 1m53s
System rebooting...
BIOS Version: 11.9
Portions Copyright (C) 2014-2018 NetApp, Inc. All Rights Reserved.
BOOTMGR: Assigned 0 out of 12 disks requested
BOOTMGR: If the disk shelves are partially populated,
Follow best practice guidelines to populate disks in the right slots
New to NetApp?
