NetApp Knowledge Base
System health alert reports Service Processor is not properly configured
7,103
Visibility:
Votes:
4
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • FAS/AFF Models
Issue
  • system health alert show reports about improper:
Cluster::> system health alert show
               Node: Cluster-01
           Resource: SP Config
           Severity: Major
    Indication Time: Fri Apr 17 09:17:32 2020
           Suppress: false
        Acknowledge: false
     Probable Cause: Service Processor is not properly configured.
    Possible Effect: You might not be able to use the Service Processor to
                     remotely access, monitor, and troubleshoot your
                     storage system.
 Corrective Actions: 1. Use the "system service-processor network modify" command to configure the network interface of the Service Processor.
                     2. Use the "system service-processor image modify -node Cluster-01 -autoupdate true" to configure AutoUpdate feature of the Service Processor.
                     3. Contact the technical support if the alert persists.
  • system health subsystem show shows degraded status for Service-Processor subsystem
Cluster::> system health subsystem show
Subsystem         Health
SAS-connect       ok
Environment       ok
Memory            ok
Service-Processor degraded
Switch-Health     ok
CIFS-NDO          ok
Motherboard       ok
IO                ok
MetroCluster      ok
MetroCluster_Node ok
FHM-Switch        ok
FHM-Bridge        ok
SAS-connect_Cluster ok
13 entries were displayed.
  • system controller show shows node in degraded status
Cluster::> system controller show
Controller Name           System ID     Serial Number     Model    Status
Cluster-01                537xxxxxx     621xxxxxxxxx      FAS2650  degraded
Cluster-02                537xxxxxx     621xxxxxxxxx      FAS2650  ok
New to NetApp?
