NetApp Knowledge Base
Sudden shelf module reboot causing both nodes to panic
548
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • NS224 Disk Shelf
  • NVMe shelf module (NSM) firmware version below 0151
Issue
  • Shortly after ONTAP upgrade to 9.8P6/P7 both nodes reboot due to multi-disk panic
  • Multiple NoPathToNSMA_Alert reported over a regular basis
  • NSM100 fw upgrade 0141 -> 0151 causing panic
  • Dec 26th all NSM firmware is on rev 0141
            Shelf 0: NS224NSM100  Firmware rev. NSM100 A: 0141  NSM100 B: 0141
            Shelf 1: NS224NSM100  Firmware rev. NSM100 A: 0141  NSM100 B: 0141
  •  NSM-A firmware upgrade started 0141 -> 0151
    Mon Dec 27 06:03:19 +0100 [node_name: dsa_worker0: sfu.downloadingController:info]: [storage download shelf]: Downloading NSM100.0151.SFW on disk shelf controller module A on 0x.shelf
  •  Node panic occurred
    Mon Dec 27 06:05:25 +0100 [node_name: config_thread: sk.panic:alert]: Panic String: aggr aggr_root: raid volfsm, fatal multi-disk error..  Raid type - raid_dp Group name plex0/rg0 state NORMAL. 10 disks failed in the group.
  • HA Node rebooted
    Mon Dec 27 06:11:48 +0100 [node_name2: send_boot_msg_thread: mgr.boot.reason_ok:notice]: System rebooted after power-on.
  • DEC 28th all NSM firmware on rev 0151
            Shelf 0: NS224NSM100  Firmware rev. NSM100 A: 0151  NSM100 B: 0151
            Shelf 1: NS224NSM100  Firmware rev. NSM100 A: 0151  NSM100 B: 0151
New to NetApp?
