NetApp Knowledge Base
Repeated cf.hwassist.missedKeepAlive errors
1,950
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • AFF
  • Cluster\Node managment network
Issue
  • Continuous HW Assist keep alive errors
  • Those cleared after a few minutes, in both nodes of an HA pair.
    EMS.Log Example:
14:03:59 +0100 [node_name01: cf_hwassist: cf.hwassist.missedKeepAlive:error]: HW-assisted takeover missing keep-alive messages from HA partner (node_name02).
14:11:29 +0100 [node_name01: cf_hwassist: cf.hwassist.recvKeepAlive:info]: hw_assist: Received hw_assist KeepAlive alert from partner(node_name02).
14:24:59 +0100 [node_name01: cf_hwassist: cf.hwassist.missedKeepAlive:error]: HW-assisted takeover missing keep-alive messages from HA partner (node_name02).
14:32:29 +0100 [node_name01: cf_hwassist: cf.hwassist.recvKeepAlive:info]: hw_assist: Received hw_assist KeepAlive alert from partner(node_name02).
15:28:00 +0100 [node_name01: cf_hwassist: cf.hwassist.missedKeepAlive:error]: HW-assisted takeover missing keep-alive messages from HA partner (node_name02).
15:35:30 +0100 [node_name01: cf_hwassist: cf.hwassist.recvKeepAlive:info]: hw_assist: Received hw_assist KeepAlive alert from partner(node_name02).
13:34:02 +0100 [node_name02: cf_hwassist: cf.hwassist.missedKeepAlive:error]: HW-assisted takeover missing keep-alive messages from HA partner (node_name01).
13:41:32 +0100 [node_name02: cf_hwassist: cf.hwassist.recvKeepAlive:info]: hw_assist: Received hw_assist KeepAlive alert from partner(node_name01).
13:55:02 +0100 [node_name02: cf_hwassist: cf.hwassist.missedKeepAlive:error]: HW-assisted takeover missing keep-alive messages from HA partner (node_name01).
14:02:32 +0100 [node_name02: cf_hwassist: cf.hwassist.recvKeepAlive:info]: hw_assist: Received hw_assist KeepAlive alert from partner(node_name01).
14:16:02 +0100 [node_name02: cf_hwassist: cf.hwassist.missedKeepAlive:error]: HW-assisted takeover missing keep-alive messages from HA partner (node_name01).
14:23:32 +0100 [node_name02: cf_hwassist: cf.hwassist.recvKeepAlive:info]: hw_assist: Received hw_assist KeepAlive alert from partner(node_name01).
  • The errors follow a timing pattern.
    Example: every 7:30 minutes.
  • Command storage failover hwassist show outputs shows the following error:
cluster::> storage failover hwassist show
Node
node-01
                    Partner: node-02
                    Hwassist Enabled: true
                    Hwassist IP: 10.XX.XX.X
                    Hwassist Port: 4444
                    Monitor Status: active
                    Inactive Reason: -
                    Corrective Action: -
                    Keep-Alive Status: Error: did not receive hwassist keep alive alerts from partner.
node-02
                    Partner: node-01
                    Hwassist Port: 4444
                    Inactive Reason: -
2 entries were displayed.
  • Command storage failover hwassist test outputs shows timed out error:
​​​​​cluster::> storage failover hwassist test -node *
Info: No response from partner(node-01).Timed out.
Info: No response from partner(node-02).Timed out.
New to NetApp?
