NetApp Knowledge Base
A800 interconnect down with e0a/e0b Fatal parity error (0x10)
3,925
Visibility:
Votes:
3
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • AFF A800, AFF C800, ASA A800, ASA C800
  • Dual 40/100G Ethernet T62100-MEZZ
  • ONTAP 9
Issue
  • After node power cycle, reboot, or upgrade, the system is in partial giveback with Interconnect status: "RDMA Interconnect is down"
  • The storage failover status is: "Storage failover interconnect error. NVRAM log not synchronized. Disk inventory not exchanged"
  • The console logs show: e0a/e0b:Fatal parity error (0x10)
  • The ONTAP OS and the BMC, BIOS and T62100 firmware are updated and running in both nodes
  • EMS logs:
May 02 07:58:09 [node_name:netif.fatal.err:ALERT]: The network device in slot 0 encountered fatal error e0a/e0b.
May 02 22:49:05 [node_name: kernel: netif.linkDown:info]: Ethernet e0a: Link down, check cable.
May 02 22:49:05 [node_name: kernel: netif.linkDown:info]: Ethernet e0b: Link down, check cable.
May 02 22:49:05 [node_name: intr: rlib.ifconfig.linkEvent:notice]: params: {'ifname': 'e0b', 'eventType': 'DOWN'}
May 02 22:49:05 -0800 [node_name: vifmgr: vifmgr.portdown:notice]: A link down event was received on node node_name, port e0a.
May 02 22:49:05 -0800 [node_name: nvmm_error: nvmm.mirror.offlined:debug]: params: {'mirror': 'HA_PARTNER'}
May 02 22:49:05 -0800 [node_name: vifmgr: vifmgr.clus.linkdown:EMERGENCY]: The cluster port e0a on node node_name has gone down unexpectedly.
May 02 23:00:00 -0800 [node_name: statd: ic.HAInterconnectDown:error]: HA interconnect: Interconnect down for 10 minutes: link0 down
May 02 23:00:00 -0800 [node_name: statd: callhome.hainterconnect.down:alert]: Call home for HA INTERCONNECT DOWN due to link0 down.
New to NetApp?
