NetApp Knowledge Base
HA links down on the nodes with internal interconnect
2,485
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • AFF A220
  • AFF A150
  • FAS 27XX
  • HA (High Availability) Interconnect
Issue
  • The HA interconnect is via the midplane and the event logs report the links as down:
Sat Oct 23 21:35:49 +0200 [node: gop_eq_thread: ic.linkStatusChange:info]: HA interconnect: Port ic0a link is down.
Sat Oct 23 21:35:49 +0200 [node: ctrl_hb_port_ic0a: ctrl.rdma.heartBeat:info]: HA interconnect: Missed heartbeat to 192.0.1.5.
Sat Oct 23 21:36:13 +0200 [node: cfdisk_config: cf.diskinventory.sendFailed:debug]: params: {'errorCode': '0', 'reason': 'HA Interconnect down'}
  • The HA links may also be seen flapping in some cases.
  • Cluster HA is disabled:
Cluster::> cluster ha show
High-Availability Configured: false
High-Availability Backend Configured (MBX): -
Warning: Cluster HA has not been configured.  Cluster HA must be configured
         on a two-node cluster to ensure data access availability in the
         event of storage failover. Use the "cluster ha modify -configured
         true" command to configure cluster HA.
  • An attempt to configure HA fails with the below error:
Cluster::> cluster ha modify -configured true
Warning: High Availability (HA) configuration for cluster services requires
         that both SFO storage failover and SFO auto-giveback be enabled. These
         actions will be performed if necessary.
Do you want to continue? {y|n}: y
Error: command failed: Could not retrieve partner SFO information: entry
       doesn't exist.
  • The links are reported as down on both nodes:
Cluster::*> system ha interconnect status show
                       Node: Node-01
                Link Status: down
         IC RDMA Connection: down
                       Node: Node-02
                Link Status: down
2 entries were displayed.
New to NetApp?
