NetApp Knowledge Base
'TCAM region is not configured' seen Cisco 3132Q when applying RCF 1.8 or later
1,168
Visibility:
Votes:
2
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
  • Cisco 3132Q Cluster switch
  • RCF 1.8 and later
WARNING
Article doesn't apply to MetroCluster IP configurations
Issue
  • When applying the 1.8 RCF (or later) to cluster switch the following alert is seen,
Unable to perform the action due to incompatibility:  Module 1 returned status "TCAM region is
not configured. Please configure TCAM region and retry the command"
  • Additional errors seen with this issue:
    ERROR: Failed to write VSH commands
    command failed: port not compatible:[Port priority-flow-control]
    ** You can use force option to override the port's parameters
    ** (e.g. "channel-group X force")
    ** Use "show port-channel compatibility-parameters" to get more information on failure
New to NetApp?
