Cluster network port does not return home after upgrading one C3132Q switch
Applies to
- Cisco N3K-C3132Q-V Cluster Network Switches (CNS) / Nexus 3132Q-V / NX3132V
- Cisco Nexus Operating System (NX-OS) upgrade along with Reference Config File (RCF) update to Cluster-HA-Breakout RCF v1.8 or later
- Two cluster LIFs/ports per node cabling with two cluster switches
Issue
- One cluster network port does not return home after upgrading one CNS
- Total packet loss when pinging from cluster lif
vifmgr: vifmgr.cluscheck.droppedall:alert]: Total packet loss when pinging from cluster lif Node1_clus1 (node Node1) to cluster lif Node2clus2 (node Node2). - Followed by VIFMgr errors
vifmgr: vifmgr.dbase.checkerror:alert]: VIFMgr experienced an error verifying cluster database consistency. Some LIFs might not be hosted properly as a result.
vifmgr: vifmgr.startup.failover.err:alert]: VIFMgr encountered errors during startup. - When just one cluster network port in one node is online, multiple rings in that node are offline (vifmgr, vldb and mgwd) with
CLUSTER NETWORK DEGRADEDerrors. - No more errors when that port is manually offlined and the cluster LIF changes the home port.
- Cable re-seat/replace/swap doesn't fix the issue.
- Controller port is properly detected on the switch side.
- All cluster network pings fail between LIFs on both switches but work for LIFs connected to the same switch.
