NetApp Knowledge Base
SwitchSNMPCommunication_Alert due to reason invalid SNMP settings
4,449
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • Cluster network switches
  • Cluster switch health monitoring (CSHM)
Issue
  • Health Monitor Alert for a Cluster switch. Example
[Node-01: cshmd: hm.alert.raised:alert]: Alert Id = SwitchSNMPCommunication_Alert , Alerting Resource = ClusterSW1 raised by monitor ethernet-switch
  • SNMP invalid settings reported for the monitored cluster switches. Example:
::> system switch ethernet show
Switch              Type              Address          Model
sw1(FOC1XXXX678)    cluster-network    10.10.10.10      OTHER
     Serial Number: Unknown
      Is Monitored: false
            Reason: Invalid SNMP Settings
  Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(4)
    Version Source: CDP
sw2(FOC1XXXX679)     cluster-network    10.10.10.10      OTHER
      Is Monitored: false
    Version Source: CDP
  • An attempt to delete the switches from monitoring and adding back fails with the below error:
::> system cluster-switch create -device cluster-switch2 -address 184.X.XX.XX -snmp-version SNMPv2c -community cshm1! -model OTHER -type cluster-network -is-monitoring-enabled-admin true
Error: SNMP validation request timed out. Verify that the "-community-or-username" value is valid.
New to NetApp?
