Is it possible to limit the IP addresses able to connect via SSH to a CN1610 switch?
Applies to
- CN1610 Cluster Network Switch
- All FASTPATH releases
Answer
It is not possible to limit or filter IP addresses able to connect via SSH directly from the switch
Additional Information
Use of an external firewall is recommended to implement access control based on IP addresses
