NetApp Knowledge Base
Who calls Cisco and opens the TAC case when there is a Cisco issue?
1,165
Visibility:
Votes:
4
Category:
fabric-interconnect-and-management-switches
Specialty:
globalops
Last Updated:
Applies to
Cisco MDS and Nexus switches purchased from NetApp
Answer
  • Contact NetApp to provide initial triage and fault isolation if the issue is uncertain
  • Contact Cisco directly if the problem is believed to be a switch issue such as powersupply failure or password reset
  • If in doubt, call NetApp first
Please Note:
  • Every Cisco technical case recommending configuration or firmware changes requires a case to be opened with NetApp
  • If subsequent determination points to Cisco, NetApp will assist the customer to raise a case with Cisco (customer Cisco.com CCOID and serial number required)
