NetApp Knowledge Base
How to troubleshoot CRC errors with BES-53248 cluster switches
1,360
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • Broadcom BES-53248 Cluster Switch
  • Similar to Cisco Nexus Switches, the BES-53248 switch uses Cut-Through switching, which means it forwards received errors out of all ports.
  • This can cause multiple cluster ports to show received CRC errors when only one link is faulty.
  • The following steps will assist in isolating the port that may be causing the issue.
New to NetApp?
