NetApp Knowledge Base
shelf disks missing and shelf ID shows 88
492
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2750
  • DS224C
Issue
  • Shelf ID shows 88
  • From sysconfig -a does not show all disks in the shelf1
00.19: NETAPP   X341_SSKBE900A10 NA01 857.0GB 520B/sect (WFK3J2N9)
00.20: NETAPP   X341_SSKBE900A10 NA01 857.0GB 520B/sect (WFK3QX8Z)
00.21: NETAPP   X341_SSKBE900A10 NA01 857.0GB 520B/sect (WFK3YJ3Z)
00.22: NETAPP   X341_SSKBE900A10 NA01 857.0GB 520B/sect (WFK3J2K9)
00.23: NETAPP   X341_SSKBE900A10 NA01 857.0GB 520B/sect (WFK3J2N0)
Shelf 0: DS224-12  Firmware rev. IOM12E A: 0120  IOM12E B: 0120
Shelf 1: DS224-12  Firmware rev. IOM12 A: 0230  IOM12 B: 0230
  • From storage fault -v all disks stauts is DEVICE OFF
Enclosure Status: critical
Channel: 0a
Shelf: 1
Shelf Type: DS224-12
Product Serial Number: SHFFG1922000132
Module Type: IOM12
Disk Elements:
Element Status                  Status Bytes  Status Descriptions
0 [Bay  0]: OK                01,00,00,10   DEVICE OFF
1 [Bay  1]: OK                01,01,00,10   DEVICE OFF
2 [Bay  2]: OK                01,02,00,10   DEVICE OFF
3 [Bay  3]: OK                01,03,00,10   DEVICE OFF
4 [Bay  4]: OK                01,04,00,10   DEVICE OFF
5 [Bay  5]: OK                01,05,00,10   DEVICE OFF
6 [Bay  6]: OK                01,06,00,10   DEVICE OFF
7 [Bay  7]: OK                01,07,00,10   DEVICE OFF
8 [Bay  8]: OK                01,08,00,10   DEVICE OFF
9 [Bay  9]: OK                01,09,00,10   DEVICE OFF
10 [Bay 10]: OK                01,0A,00,10   DEVICE OFF
11 [Bay 11]: OK                01,0B,00,10   DEVICE OFF
12 [Bay 12]: OK                01,0C,00,10   DEVICE OFF
13 [Bay 13]: OK                01,0D,00,10   DEVICE OFF
14 [Bay 14]: OK                01,0E,00,10   DEVICE OFF
15 [Bay 15]: OK                01,0F,00,10   DEVICE OFF
16 [Bay 16]: OK                01,10,00,10   DEVICE OFF
17 [Bay 17]: OK                01,11,00,10   DEVICE OFF
18 [Bay 18]: OK                01,12,00,10   DEVICE OFF
19 [Bay 19]: OK                01,13,00,10   DEVICE OFF
20 [Bay 20]: OK                01,14,00,10   DEVICE OFF
21 [Bay 21]: OK                01,15,00,10   DEVICE OFF
22 [Bay 22]: OK                01,16,00,10   DEVICE OFF
23 [Bay 23]: OK                01,17,00,10   DEVICE OFF
  • In some cases, only the shelf ID may be mistakenly displayed as 88, and there may be no issues with the hardware.
New to NetApp?
