Why does AFF or ASA storage config show as Single-Path HA
Applies to
- AFF-A800, AFF-C800, ASA-A800, ASA-C800
- AFF-A250, AFF-C250, ASA-A250, ASA-C250, FAS500f
- Internal-only NVMe storage drives
Answer
- An AFF or ASA storage system installed with internal-only NVMe solid-state drives (SSDs) will show Single-Path HA for its System Storage Configuration in sysconfig nodeshell CLI output:
NetApp Release 9.7P4: Fri May 22 20:45:51 EDT 2020 System ID: 0123456789 (aff-a800-01); partner ID: 0123456780 (aff-a800-02) System Serial Number: 952016123456 (aff-a800-01) System Rev: C3 System Storage Configuration: Single-Path HA System ACP Connectivity: Inband Active SAS2/SAS3 Mixed Stack Support: all All-Flash Optimized: true Capacity Optimized: false All SAN Array: false Backplane Part Number: 1A21RNK00+A0 Backplane Serial Number: SHFGB00000000 . . slot 0: Virtual NVMe Host Adapter 0n 0 : NETAPP X4014S173315TNTE NA50 14651.0GB 4160B/sect (S60SNE0N502096) 1 : NETAPP X4014S173315TNTE NA50 14651.0GB 4160B/sect (S60SNE0N502044) 2 : NETAPP X4014S173315TNTE NA50 14651.0GB 4160B/sect (S60SNE0N502050) . . 45 : NETAPP X4014S173315TNTE NA50 14651.0GB 4160B/sect (S60SNE0N502046) 46 : NETAPP X4014S173315TNTE NA50 14651.0GB 4160B/sect (S60SNE0N502043) 47 : NETAPP X4014S173315TNTE NA50 14651.0GB 4160B/sect (S60SNE0N502045) Shelf 0: FS4483PSM3E Firmware rev. PSM3E A: 0120 PSM3E B: 0120
- Single-Path HA is expected and normal
- Each controller in the chassis has a single direct PCIe-based connection to each NVMe SSD installed in the system's internal shelf.
- Host Bus Adapter (HBA) ports for these internal connections are virtual, i.e.
- If external storage shelves are added to the system, then System Storage Configuration should show as Multi-Path HA if the external shelves are correctly cabled.
Additional Information
- For external storage shelf supported by a specific storage system, see: NetApp Hardware Universe
