WAFL inconsistent user data block due to raid.cksum.bad.file.block error
Applies to
- ONTAP 9
- Multiple models of disks
Issue
- Multiple disks and models reporting Medium errors. Example:
[node_name: disk_server_0: disk.ioMediumError:notice]: Medium error on disk 0a.01.1: op 0x2f:0cf77000:0400 sector 217542656 SCSI:medium error - - If the disk is in a RAID group, the subsystem will attempt to reconstruct unreadable data...
[node_name: disk_server_0: disk.ioMediumError:notice]: Medium error on disk 0a.02.2: op 0x07 sector 0 SCSI:medium error - - If the disk is in a RAID group, the subsystem will attempt to reconstruct unreadable data...
[node_name: disk_server_1: disk.ioMediumError:notice]: Medium error on disk 0a.03.3: op 0x2a:68cb8590:0008 sector 1758168464 SCSI:medium error - - If the disk is in a RAID group, the subsystem will attempt to reconstruct unreadable data...
- Bad block checksum reported. Example:
node_name ERROR raid.cksum.bad.file.block: Reading bad block on volume vol_name, Disk /aggr/plex0/rg0/0a.00.1 Shelf 0 Bay 1 (...) UID [...], disk block 24668672,...
- WAFL inconsistency triggered for that. Example:
[node_name: wafl_exempt07: wafl.raid.incons.userdata:error]: WAFL inconsistent: inconsistent user data block at VBN 16039896320 (vvbn:1028691064 fbn:2137234048 level:0) in public inode (fileid:96 snapid:0 file_type:15 disk_flags:0x8402 error:120 raid_set:1) in volume vol_name...
