NetApp Knowledge Base
Storage show fault reports "ENCLOSURE BYPASSED"
4,789
Visibility:
Votes:
1
Category:
disk-shelves
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
Issue
  • ENCLOSURE BYPASSED can be found in storage show fault.
> storage show fault -v
Enclosure Status: non-critical
Channel: 3c
Shelf: 1
Shelf Type: DS4246
Product Serial Number: XXXXXXXXXXXX
Module Type: IOM6
Disk Elements:
Element Status                  Status Bytes  Status Descriptions
 19 [Bay 19]: OK                01,13,00,00
 20 [Bay 20]: NONCRITICAL       03,14,10,04   ENCLOSURE BYPASSED B, BYPASSED B
 21 [Bay 21]: OK                01,15,00,00
  • sysconfig -a shows the effected disk is normal.
 slot 0: SAS Host Adapter 0a (PMC-Sierra PM8001 rev. C, SAS, <UP>)
  Firmware rev:       01.11.00.00
  Base WWN:           5:00a098:0014dc6:88
  Phy State:          [0] Enabled, 6.0 Gb/s
                      [1] Enabled, 6.0 Gb/s
                      [2] Enabled, 6.0 Gb/s
                      [3] Enabled, 6.0 Gb/s
  QSFP Vendor:        Molex Inc.
  QSFP Part Number:   112-00176+A0
  QSFP Type:          Passive Copper 0.5m ID:00
  QSFP Serial Number: 235621256
                01.19: NETAPP   X308_SMNRY03TSSA NA00 2538.5GB 512B/sect (Z297CDM7)
                01.20: NETAPP   X308_THARR03TSSM NA00 2538.5GB 512B/sect (16S3K7ZUF)
                01.21: NETAPP   X308_THARR03TSSM NA00 2538.5GB 512B/sect (16SDK6P1F)
New to NetApp?
