NetApp Knowledge Base
Shelf reported as unknown from sysconfig -a output
737
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
Applies to
  • FAS systems
  • ONTAP 9
  • DS2246 disk shelves
Issue
  • Disk shelf status is reported as unknown through one adapter on both nodes in the HA pair:
::> system node run -node * sysconfig -a
Node-01
slot 0: SAS Host Adapter 0d (PMC-Sierra PM8001 rev. C, SAS, <UP>)
        Firmware rev:       01.12.09.00
        Shelf 27: DS2246  Firmware rev. IOM6 A: 0191  IOM6 B: 0191
        Shelf 28: DS2246  Firmware rev. IOM6 A: 0191  IOM6 B: 0191
        Shelf ?: unknown NUTAPP:DS224IOM6
Node-02
slot 4: SAS Host Adapter 4c (PMC-Sierra PM8001 rev. C, SAS, <UP>)
        MFG Part Number:    USI 6086-000010-07 rev. MP V4.10
  • The same shelf is reported normally from the other adapter:
::> system node run -node <node> sysconfig -a
slot 4: SAS Host Adapter 4a (PMC-Sierra PM8001 rev. C, SAS, <UP>)
        Shelf 29: DS2246  Firmware rev. IOM6 A: 0191  IOM6 B: 0191
  • Both nodes are connected to a common IOM through the adapter that reports the shelf as unknown:
::> system node run -node * -command sasadmin expander_map
Node-01
Expanders on channel 0d:
Level    8: WWN 500a0XXXXXXXX5ff, ID 27, Serial Number ' SHFMSXXXXXXXX27', Product 'DS224IOM6       ', Rev '0191', Slot B
Level    9: WWN 500a0XXXXXXXX2ff, ID 28, Serial Number ' SHFMSXXXXXXXX28', Product 'DS224IOM6       ', Rev '0191', Slot B
Level   10: WWN 500a0XXXXXXXX03f, ID 29, Serial Number ' SHFMSXXXXXXXX29', Product 'DS224IOM6       ', Rev '0191', Slot B
Node-02
Expanders on channel 4c:
Level    1: WWN 500a0XXXXXXXX03f, ID 29, Serial Number ' SHFMSXXXXXXXX29', Product 'DS224IOM6       ', Rev '0191', Slot B
Level    2: WWN 500a0XXXXXXXX2ff, ID 28, Serial Number ' SHFMSXXXXXXXX28', Product 'DS224IOM6       ', Rev '0191', Slot B
Level    3: WWN 500a0XXXXXXXX5ff, ID 27, Serial Number ' SHFMSXXXXXXXX27', Product 'DS224IOM6       ', Rev '0191', Slot B
  • The disks are detected normally from both adapters.
  • The following event may be reported in the event logs:
[Node-01: dsa_disc: ses.shelf.unsupportAllowErr:alert]: Unsupported disk shelf found on channel 0d.
  • Reseat of the affected IOM does not resolve the issue.
New to NetApp?
