Reconstruction does not start after disk replacement using ADP
Applies to
- FAS2554
- ONTAP 9
- Advanced Disk Partitioning (ADP)
Issue
- The disk Shelf 0 bay 4 has failed, so replace the new disk, but not recognize.
- The RAID group "
n1_aggr1
" has degraded and neither the existing spare disks in pool0 nor the new disk cannot reconstruct.
Example of node-2 sysconfig -r:
Aggregate n1_aggr1 (online, raid_dp, degraded) (block checksums)
Plex /n1_aggr1/plex0 (online, normal, active, pool0)
RAID group /n1_aggr1/plex0/rg0 (degraded, block checksums)
RAID Disk Device HA SHELF BAY CHAN Pool Type RPM Used (MB/blks) Phys (MB/blks)
dparity 0a.00.0P1 0a 0 0 SA:B 0 FSAS 7200 3660678/7497068544 3660686/7497084928
parity 0a.00.1P1 0a 0 1 SA:B 0 FSAS 7200 3660678/7497068544 3660686/7497084928
data 0a.00.2P1 0a 0 2 SA:B 0 FSAS 7200 3660678/7497068544 3660686/7497084928
data 0a.00.3P1 0a 0 3 SA:B 0 FSAS 7200 3660678/7497068544 3660686/7497084928
data FAILED N/A 3660678/ -
data 0a.00.5P1 0a 0 5 SA:B 0 FSAS 7200 3660678/7497068544 3660686/7497084928
data 0a.00.6P1 0a 0 6 SA:B 0 FSAS 7200 3660678/7497068544 3660686/7497084928
data 0a.00.7P1 0a 0 7 SA:B 0 FSAS 7200 3660678/7497068544 3660686/7497084928
data 0a.00.8P1 0a 0 8 SA:B 0 FSAS 7200 3660678/7497068544 3660686/7497084928
data 0a.00.9P1 0a 0 9 SA:B 0 FSAS 7200 3660678/7497068544 3660686/7497084928
Aggregate n2_aggr1 (online, raid_dp) (block checksums)
Plex /n2_aggr1/plex0 (online, normal, active, pool0)
RAID group /n2_aggr1/plex0/rg0 (normal, block checksums)
dparity 0b.10.0 0b 10 0 SA:A 0 SAS 10000 1142352/2339537408 1144641/2344225968
parity 0b.10.1 0b 10 1 SA:A 0 SAS 10000 1142352/2339537408 1144641/2344225968
data 0b.10.2 0b 10 2 SA:A 0 SAS 10000 1142352/2339537408 1144641/2344225968
data 0b.10.3 0b 10 3 SA:A 0 SAS 10000 1142352/2339537408 1144641/2344225968
data 0b.10.4 0b 10 4 SA:A 0 SAS 10000 1142352/2339537408 1144641/2344225968
data 0b.10.5 0b 10 5 SA:A 0 SAS 10000 1142352/2339537408 1144641/2344225968
data 0b.10.6 0b 10 6 SA:A 0 SAS 10000 1142352/2339537408 1144641/2344225968
data 0b.10.7 0b
10 7 SA:A 0 SAS 10000 1142352/2339537408 1144641/2344225968
data 0b.10.8 0b 10 8 SA:A 0 SAS 10000 1142352/2339537408 1144641/2344225968
data 0b.10.9 0b 10 9 SA:A 0 SAS 10000 1142352/2339537408 1144641/2344225968
Aggregate n2_aggr0 (online, raid_dp) (block checksums)
Plex /n2_aggr0/plex0 (online, normal, active, pool0)
RAID group /n2_aggr0/plex0/rg0 (normal, block checksums)
dparity 0a.00.0P2 0a 0 0 SA:B 0 FSAS 7200 147102/301265408 147110/301281792
parity 0a.00.2P2 0a 0 2 SA:B 0 FSAS 7200 147102/301265408 147110/301281792
data 0a.00.10P2 0a 0 10 SA:B 0 FSAS 7200 147102/301265408 147110/301281792
data 0a.00.6P2 0a 0 6 SA:B 0 FSAS 7200 147102/301265408 147110/301281792
data 0a.00.8P2 0a 0 8 SA:B 0 FSAS 7200 147102/301265408 147110/301281792
Pool1 spare disks (empty)
Pool0 spare disks
Spare disks for block checksum
spare 0b.10.10 0b 10 10 SA:A 0 SAS 10000 1142352/2339537408 1144641/2344225968
spare 0b.10.11 0b 10 11 SA:A 0 SAS 10000 1142352/2339537408 1144641/2344225968
spare 0b.00.4P2 0b 0 4 SA:A 0 FSAS 7200 147102/301265408 147110/301281792
n1_aggr1
" are configured partition P1 disks, so moving the partition P1 disks from partner node-1, but reconstruction still doesn't start.
data
data 0b.10.7 0b 10 7 SA:A 0 SAS 10000 1142352/2339537408 1144641/2344225968
Pool0 spare disks
spare 0a.00.4P2 0a 0 4 SA:B 0 FSAS 7200 147102/301265408 147110/301281792
spare 0a.00.4P1 0a 0 4 SA:B 0 FSAS 7200 3660678/7497068544 3660686/7497084928
spare 0a.00.10P1 0a 0 10 SA:B 0 FSAS 7200 3660678/7497068544 3660686/7497084928
spare 0a.00.11P1 0a 0 11 SA:B 0 FSAS 7200 3660678/7497068544 3660686/7497084928
