NetApp Knowledge Base
Panic : Missing or invalid System ID
1,292
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • AFF A700
  • FAS9000
Issue
  • The following panic occurs
WARNING: Unable to get sysid!
PANIC  : Missing/invalid System ID: bootarg.frurom.fileid=<0>.
version: 9.7P5: Tue Jun 23 00:04:35 EDT 2020
conf   : x86_64.optimize
cpuid = 14
Uptime: 16s
ahcich0: AHCI reset done: devices=00000001
coredump: primary dumper is not yet registered this early during system initialization. A coredump will not be available at this time.
coredump: secondary dumper is not yet registered this early during system initialization. A coredump will not be available at this time.
System halting...
BIOS Version: 10.7
Portions Copyright (C) 2014-2017 NetApp, Inc. All Rights Reserved.
Initializing System Memory ...
Loading Device Drivers ...
IPMI PCI Slot Configuration failed.
Configuring Devices ...
Device(s) in slot missing, attempting to recover it.
System is resetting.
BIOS Version: 10.7
CPU = 2 Processor(s) Detected.
  Intel(R) Xeon(R) CPU E5-2697 v4 @ 2.30GHz (CPU 0)
  CPUID: 0x000406F1. Cores per Processor = 18
  Intel(R) Xeon(R) CPU E5-2697 v4 @ 2.30GHz (CPU 1)
524288 MB System RAM Installed.
SATA (AHCI) Device: SV9MST6D120GLM41NP
Boot Loader version 6.0.8
Copyright (C) 2000-2003 Broadcom Corporation.
Portions Copyright (C) 2002-2018 NetApp, Inc. All Rights Reserved.
BIOS POST Failure(s) detected: PCIe device missing error detected. Abort AUTOBOOT
  • There is no partner-sysid in printenv output
LOADER-B> printenv
Variable Name        Value
ARCH                 X86_64
AUTOBOOT             true
AUTOBOOT_FROM        PRIMARY
AUTO_FW_UPDATE       true
BACKUP_BIOS_VERSION  10.5
BIOS_DATE            Tue 10/22/2019
BIOS_INTERFACE       40000000000400C7
BIOS_VERSION         10.7
BOARDNAME            SB_XXI
bootarg.frurom.fileid 0
bootarg.init.flash_optimized true
BOOTED_FROM          OTHER
boot_backup          setenv BOOTED_FROM BACKUP; boot -elf64 $GX_BACKUP_KERNEL_URL
BOOT_CONSOLE         eficons0a
boot_diags           boot -sld -elf64 $GX_DIAG_URL
BOOT_FLASH           flash0a
boot_ontap           autoboot
boot_primary         setenv BOOTED_FROM PRIMARY; boot -elf64 $GX_PRIMARY_KERNEL_URL
BT_BIOS_VERSION      10.7
BT_LOADER_VERSION    6.0.8
CPU_NUM_CORES        36
CPU_SPEED            2300
CPU_TYPE             Intel(R) Xeon(R) CPU E5-2697 v4 @ 2.30GHz
ENABLE_SMI           false
ENV_VERSION          1
FIRMWARE_URL         fat://boot0/X86_64/firmware/SB_XXI/firmware.img
GX_BACKUP_KERNEL_URL fat://boot0/X86_64/freebsd/image2/kernel
GX_DIAG_URL          fat://boot0/X86_64/freebsd/image1/kernel
GX_PRIMARY_KERNEL_URL fat://boot0/X86_64/freebsd/image1/kernel
ldkern               load -elf64 $GX_PRIMARY_KERNEL_URL
MOBO_MODEL           FAS9000
MOBO_REV             F0
MOBO_SERIAL_NUM      031939000543
MOBO_VENDOR          NetApp, Inc.
netboot              setenv BOOTED_FROM NETWORK; boot -elf64
ntap.init.kernelname X86_64/freebsd/image1/kernel
OEM_TYPE_2/0/29/0/0x8086/0x8D26 0/u/b
OEM_TYPE_2/0/31/2/0x8086/0x8D02 0/u/a
OEM_TYPE_2/173/0/0/0x11F8/0x8072 9/#/#
OEM_TYPE_2/207/0/0/0x10B5/0x8732 10/#/#
OEM_TYPE_2/208/8/0/0x10B5/0x8732 10/#/#
OEM_TYPE_2/208/9/0/0x10B5/0x8732 10/#/#
OEM_TYPE_2/209/0/0/0x8086/0x1584 10/#/#
OEM_TYPE_2/210/0/0/0x8086/0x1584 10/#/#
OEM_TYPE_2/57/0/0/0x10B5/0x8732 4/#/#
OEM_TYPE_2/58/8/0/0x10B5/0x8732 4/#/#
OEM_TYPE_2/58/9/0/0x10B5/0x8732 4/#/#
OEM_TYPE_2/59/0/0/0x8086/0x1584 4/#/#
OEM_TYPE_2/59/0/1/0x8086/0x1584 4/#/#
OEM_TYPE_2/59/0/2/0x8086/0x1584 4/#/#
OEM_TYPE_2/59/0/3/0x8086/0x1584 4/#/#
OEM_TYPE_2/60/0/0/0x8086/0x1584 4/#/#
OEM_TYPE_2/60/0/1/0x8086/0x1584 4/#/#
OEM_TYPE_2/60/0/2/0x8086/0x1584 4/#/#
OEM_TYPE_2/60/0/3/0x8086/0x1584 4/#/#
OEM_TYPE_2/96/0/0/0x8086/0x1533 0/e/M
OEM_TYPE_3           0/0/31/2/u0a.0/SV9MST6D120GLM41NP;
OEM_TYPE_4           32768/0/4096/0xC7FE8000
PRIMARY_BIOS_VERSION 10.7
savenv               saveenv
sysvar.init.boot.varfs.restore.success true
SYS_MODEL            FAS9000
SYS_REV              A1
SYS_SERIAL_NUM       xxxxxxxxxxxxx
update_flash         flash -backup $FIRMWARE_URL flash0a
USE_SECONDARY        false
vm.pci.mmio.64.addr  0xc000000000
vm.pci.mmio.64.size  0x3ffc000000
  • Slot 6 missing is displayed in the events all output
Record 2444: Mon May 16 02:53:06.837889 2022 [SP.notice]: PCIE Config Info received from BIOS
Record 2445: Mon May 16 02:53:06.894052 2022 [SP.notice]: ScratchPad Config Info received from BIOS
Record 2446: Mon May 16 02:53:10.215127 2022 [IPMI.notice]: (PUA) Enable power to all PCIe slots
Record 2447: Mon May 16 02:53:10.224249 2022 [IPMI.notice]: (PUA) Enable power to all PCIe on board device
Record 2448: Mon May 16 02:53:10.000000 2022 [SysFW.notice]: BIOS Version: 10.7
Record 2449: Mon May 16 02:53:10.274365 2022 [IPMI.notice]: (PUA) P_stat :slots=0x0,onboard_devs=0x0,final
Record 2450: Mon May 16 02:53:10.274422 2022 [IPMI.notice]: (PUA) Power status of all PCIe slots unchanged
Record 2451: Mon May 16 02:53:16.564218 2022 [IPMI.notice]: 7502 | 02 | EVT: 01500f14 | Bat_Rem_Cap | Assertion Event, "Lower Non-critical going low " | Reading: 0.375 | Threshold: 0.500
Record 2452: Mon May 16 02:53:19.000000 2022 [SysFW.critical]: IPMI PCI Slot Configuration failed.
Record 2453: Mon May 16 02:53:19.432640 2022 [Trap Event.critical]: hwassist post_error (26)
Record 2454: Mon May 16 02:53:24.000000 2022 [SysFW.notice]: Device 94/0/0 (SLOT-6-CPU0) missing
Record 2455: Mon May 16 02:53:25.456187 2022 [IPMI.notice]: 7602 | 02 | EVT: 6f02ffff | PCM_Status | Assertion Event, "Fault"
Record 2456: Mon May 16 02:53:27.000000 2022 [SysFW.notice]: Device(s) in slot missing, attempting to recover it.
New to NetApp?
