NetApp Knowledge Base
PANIC : ECC error at DIMM-XX, Uncorrectable Machine Check Error Resolution guide
7,083
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • AFF, ASA and FAS systems
  • Uncorrectable Error Correction Code (UECC) memory errors on:
    • System memory DIMM
    • NV-DIMM
    • NVRAM DIMM
This procedure provides a guide to the correct remediation actions when a controller experiences a panic/reboot or a power-cycle due to an uncorrectable memory error on a system memory DIMM, NV-DIMM or NVRAM DIMM.
Examples:
PANIC: ECC error at DIMM-18: 2C-0F-2007-2664E6BE,ADDR 0x180a048b40,(Node(1), Memory controller(1), CH(3), DIMM(0), Rank(0), Bank Group(1), Bank(0x0), Row(0xb8b1), Col(0x2f8), Uncorrectable Machine Check Error at CPU21.
NVRAM in slot 6: uncorrectable memory error at address 0x99f60628 DIMM(1), Rank(0), Bank Group(0), Bank(0x0), Row(0x99f6), Col(0x1d) in process idle
PANIC: Uncorrectable Machine Check Error at CPU14. ECC error at DIMM-13: CE-01-1941-03A203B8,ADDR 0x15f09e1f40,(Node(1), Memory controller(0), CH(1), DIMM(0),Rank(0), Bank Group(3), Bank(0x0), Row(0x15e0f), Col(0x70)) SKL_IMC0 Error: STATUS<0xfe0000c001010091>(VALID,OVERFLOW,UC,EN,MISCV,ADDRV,PCC,CORR_ERR_STATUS(0),CORR_ERR_CNT(0x3),OTHER_INFO(0),MscodDdrType(0x1),MscodDataRdErr,MCACOD(0x91))MISC<0x200400c00fc02086>(DataErrorChunk(0x2),McCmdChnl(0x1),McCmdMemRegion(0),McCmdOpcode(0),McCmdVld,SmiAD,SmiMsgClass(0),SmiOpcode(0),TrkId(0x7e),Error_Type(0x4),ADDRMODE(0x2),ADDRLSB(0x6))ADDR<0x00000015f09e1f40>(HIPHYADDR(0x15),LOPHYADDR(0x3c2787d))(Node(1), Memory controller(0), CH(1), DIMM(0), Rank(0), Bank Group(3), Bank(0x0), Row(0x15e0f), Col(0x70)
Uncorrectable Machine Check Error at CPU14. SPR_UBOX Error: STATUS<0xfa00000000000e0b>(VALID,OVER,UC,EN,MISCV,PCC,CESI(0),CERR_CNT(0),OTHER_INFO(0),MSCOD(0),MCACOD(0xe0b))MISC<0x00000000480200 00>(BUS_LOG(0x48),DEVICE_LOG(0),FUNCTION_LOG(0x2),SEGMENT_LOG(0)) IIO Machine Check from devices(s): SPR:Socket0:IIO-Stack5:RAS(72,0,2):M2IOS <0x00000015>(RasFuncNerr(0),RasSevNerr(0),RasFuncFerr(0x2),RasSevFerr(0x2),RasStsFerr), M2IOSSTS <0x00000100>(IRPSev2), IRPRING <0x00000001>(BLPErr), IRPRINGFF <0x00000001>(BLPErr), IRPRINGMISC <0x0000001b>(BLPBit4,BLPBit3,BLPBit1,BLPBit0), IRPPoisonLog <0xe0002082>(PoiLogOv,PoiLogTtype(0),PoiLogLen(0x10),PoiLogRid(0x20),PoiLogType(0x2)), ADDRL <0xa8935840>((0xa8935840)), ADDRH <0x00002048>((0x2048)), NETAPP NVRAM12 in slot 4 on Controller, SPR:Socket0:IIO-Stack5:RPT(72,1,0): Status(SigSysErr,DtParErr), SecStatus(DataPar,RcvSysErr), ErrSrcID(CorrSrc(0),UCorrSrc(0x4900)), . SPR_BANK8_MDF Error: STATUS<0xba00000000400405>(VALID,UC,EN,MISCV,PCC,ERR_STATUS(0),MSCOD(0),MCCOD(0x40),MCC
ONTAP 9.10.1 and later:
  • Starting with ONTAP 9.10.1, the system no longer experiences a panic in order to avoid the unnecessary coredump operation.
  • Instead, an uncorrectable memory error is logged on the system console and a hw-asssist notification from that node's BMC to its HA partner to immediately take over. Then, the node initiates a power-cycle reset.
  • Example UECC DIMM error message:
ECC error at DIMM-13: 2C-0F-1936-23BB32F7,ADDR 0x1081427700,(Node(1), Memory controller(0), CH(1), DIMM(0), Rank(0), Bank Group(0), Bank(0x2), Row(0x10021), Col(0x1d0)) Uncorrectable Machine Check Error at CPU18. SKL_IMC0 Error: ...
  • Example of the EMS event generated on the HA partner:
cf_hwassist: cf.hwassist.takeoverTrapRecv:debug]: hw_assist: Received takeover hw_assist alert from partner(node02), system_down because dimm_uecc_error.
New to NetApp?
