NetApp Knowledge Base
MGWD reports removing unmapped port in CDB
339
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
CORE
Last Updated:
Applies to
  • FAS2552
  • ONTAP 9.3P19
Issue
  • network port show network port is removed from default broadcast domain but still remains in default IPSPACE:
Vserver0::> network port show
Node: hostname1
                                                  Speed(Mbps) Health
Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status
e0a       Default      -                up   1500  1000/1000  healthy
  • sysconfig -a shows network port is up:
slot 0: Gigabit Ethernet Controller 82580
    e0a MAC Address:    xx:xx:xx:xx:xx:xx (auto-1000t-fd-up)
  • vifmgr.log raises warning:
Line 1271: 0000003d.0000110f 0000192f Wed Jul 21 2021 15:42:25 +09:00 [kern_vifmgr:info:5986] [0x80bd5cb00] [FailoverMgr::removeInvalidPhysPorts] removed invalid port e0a
Mon Jul 26 2021 12:00:12 +09:00 [kern_vifmgr:info:6073] [0x80bd5cb00] [Startup_Merge::cdb_to_rdb_merge] Updating port e0a to use port role data
Mon Jul 26 2021 12:00:12 +09:00 [kern_vifmgr:info:6073] [0x80bd5cb00] [Startup_Merge::cdb_to_rdb_merge] port_bdchange: Clearing broadcast domain for port e0a, because it has moved to an IPspace other than Cluster
Mon Jul 26 2021 12:00:12 +09:00 [kern_vifmgr:info:6073] [0x80bd5cb00] [Startup_Merge::cdb_to_rdb_merge] Updating port e0a to use ipspace id 1111111111
Mon Jul 26 2021 12:00:12 +09:00 [kern_vifmgr:info:6073] [0x80bd5cb00] [Startup_Merge::cdb_to_rdb_merge] correcting autoneg for port e0a in RDB (false)
  • mgwd.log raises warning:
0x81bc04200: 0: ERR: net_ports: scan_local_netports, src/tables/net_ports.cc:417 failed to assign port e0a to IPspace -1 for cdb entry (hostname1;e0a): success 0000003d.00000435 000017b3 Wed Jul 21 2021 15:41:42 +09:00 [kern_mgwd:info:2006] 0x81bc04200: 0: NOTICE: net_ports: scan_local_netports, src/tables/net_ports.cc:431 removing unmapped port in CDB (e0a)
New to NetApp?
