NetApp Knowledge Base
Incorrect Shelf Sensor Thresholds after maintenance or replacement
158
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS Systems
  • AFF Systems
Issue
Following hardware maintenance/replacement, the thresholds of the shelf sensors are incorrect in the environment logs. This is only reported incorrectly by one node, and the partner reports correctly.
Example:
	Temperature thresholds by element:
	  [1] High critical: 52 C (125 F); high warning: 47 C (116 F)
	      Low critical:  0 C (32 F); low warning:  5 C (41 F)
	  [2] High critical: 60 C (140 F); high warning: 55 C (131 F)
	  [3] High critical: 60 C (140 F); high warning: 55 C (131 F)
	  [4] High critical: 60 C (140 F); high warning: 55 C (131 F)
	  [5] High critical: 60 C (140 F); high warning: 55 C (131 F)
	  [6] High critical: 62 C (143 F); high warning: 57 C (134 F)
	      Low critical:  5 C (41 F); low warning:  10 C (50 F)
	  [7] High critical: 100 C (212 F); high warning: 95 C (203 F)
	  [8] High critical: 62 C (143 F); high warning: 57 C (134 F)
	  [9] High critical: 100 C (212 F); high warning: 95 C (203 F)
	  [10] High critical: 90 C (194 F); high warning: 80 C (176 F)
	  [11] High critical: 100 C (212 F); high warning: 79 C (174 F)
	  [12] High critical: 75 C (167 F); high warning: 60 C (140 F)
	  [13] High critical: 65516 C (117960 F); high warning: 65516 C (117960 F)
	      Low critical:  65516 C (117960 F); low warning:  65516 C (117960 F)
	  [14] High critical: 65516 C (117960 F); high warning: 65516 C (117960 F)
	  [15] High critical: 65516 C (117960 F); high warning: 65516 C (117960 F)
New to NetApp?
