NetApp Knowledge Base
How to view disk zeroing status of a partitioned disk in ONTAP
11,152
Visibility:
Votes:
5
Category:
disk-drives
Specialty:
hw
Last Updated:
Applies to
ONTAP 9
  • This article describes the procedure to check disk zeroing status of a partitioned disk.
  • Zeroing a disk writes zeros to the entire disk and must be done before a disk can be reused in another aggregate.
  • The storage disk zero spares command zeroes out all non-zeroed RAID spare disks.
  • The command runs in the background and can take much time to complete, possibly hours, depending on the number of disks to be zeroed and the capacity of each disk.
  • Having zeroed spare disks available helps avoid delay in creating or extending an aggregate.
  • Spare disks that are in the process of zeroing are still eligible for use as creation, extension, or reconstruct disks.
New to NetApp?
