NetApp Knowledge Base
How to update the SP/BMC Internal Ethernet switch firmware?
1,194
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
Platforms Firmware
AFF A700, FAS9000 SP 4.7 , 4.8
AFF A200, FAS2620, FAS2650,AFF A300, FAS8200 SP 5.6P1 , 5.7, 5.8
  • Some NetApp controller families utilize an internal Ethernet switch that may need to be manually updated after the Service Processor (SP) / Baseboard Management Controller (BMC) firmware has been updated.
  • The switch firmware is not automatically updated if the SP/BMC firmware is updated.
    • Verify the switch firmware version after any ONTAP upgrade, and if required manually update the switch firmware according to the instructions for that specific model and SP/BMC version
New to NetApp?
