How to suppress SPNotConfiguredAlert
- 567
- Visibility:
- Public
- Votes:
- 0
- Category:
- fas-systems
- Specialty:
- core
- Last Updated:
- 10/27/2022, 5:25:23 AM
Applies to
- FAS2720
- FAS2750
- Service Processor(SP)
SPNotConfiguredAlert is generated when customer is not willing to config the SP network.
Cluster::> system health alert show -instance
Node: Cluster-1
Monitor: controller
Alert ID: SPNotConfiguredAlert
Alerting Resource: SP Config
Subsystem: Service-Processor
Indication Time: Wed Sep 28 19:39:56 2022
Perceived Severity: Major
Probable Cause: Configuration_error
Description: Service Processor is not properly configured.
Corrective Actions: 1. Use the "system service-processor network modify" command to configure the network interface of the Service Processor.
2. Use the "system service-processor image modify -node Cluster-1 -autoupdate true" to configure AutoUpdate feature of the Service Processor.
3. Contact the technical support if the alert persists.
Possible Effect: You might not be able to use the Service Processor to remotely access, monitor, and troubleshoot your storage system.
Acknowledge: false
Suppress: false
Policy: SPNotConfiguredAlertPolicy
Acknowledger: -
Suppressor: -
Additional Information: Status: online
Configured: false
Firmware Version: 5.10
Booted Version : primary
Public Link Status: down
Warning Count: 5
Link Warning Count: 5
Alerting Resource Name: SP Config
Additional Alert Tags: device
