NetApp Knowledge Base
How to read IFSTAT counters on your AFF/FAS systems
5,150
Visibility:
Votes:
4
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • Clustered Data ONTAP 8
  • Data ONTAP 7-mode
Data ONTAP 7-mode
node_name> ifstat [ -z ] -a | <interface_name>
Clustered Data ONTAP 8 and ONTAP 9
The command is executed from the Nodeshell of each node
cluster::> system node run -node <node_name> -command ifstat [ -z ] -a | <interface_name>
Output example
cluster::> system node run -node node_example> -command ifstat e0a
-- interface  e0a  (6 days, 19 hours, 46 minutes, 1 second) --
RECEIVE
 Frames/second:       6  | Bytes/second:      551  | Errors/minute:       0
 Discards/minute:     0  | Total frames:      249k | Total bytes:     19489k
 Total errors:        0  | Total discards:      0  | Multi/broadcast:   235k
 No buffers:          0  | Non-primary u/c:     0  | L2 terminate:        0
 Tag drop:            0  | Vlan tag drop:       0  | Vlan untag drop:     0
 Vlan forwards:       0  | Vlan broadcasts:     0  | Vlan unicasts:       0
 CRC errors:          0  | Alignment errors:    0  | Runt frames:         0
 Long frames:         0  | Fragment:            0  | Jabber:              0
 Xon:                 0  | Xoff:                0  | Ring full:           0
 Jumbo:               0  | Jumbo error:         0  | Index error:         0
 Force wakeup:        0
TRANSMIT
 Frames/second:       4  | Bytes/second:      659  | Errors/minute:       0
 Discards/minute:     0  | Total frames:    26386  | Total bytes:      2443k
 Total errors:        0  | Total discards:      0  | Multi/broadcast: 11256
 Queue overflows:     0  | No buffers:          0  | Single collision:    0
 Multi collisions:    0  | Late collisions:     0  | Max collisions:      0
 Deferred:            0  | Xon:                 0  | Xoff:                0
 MAC Internal:        0  | Jumbo:               0
LINK_INFO
 Current state:       up | Up to downs:         0  | Speed:            1000m
 Duplex:            full | Flowcontrol:       full
Note:
  • The -z argument clears the statistics
  • The -a argument displays statistics for all network interfaces including the virtual host and the loopback address. Optionally, you can leave off the -a argument and specify the name of a network interface.
New to NetApp?
