NetApp Knowledge Base
How to Identify the Serial Number of an ONTAP Platform?
16,809
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • AFF Systems
  • ASA Systems
  • FAS Systems
This article provides the steps to identify the serial number of an ONTAP platform, using both command line and System Manager.
Procedure
System Manager
  1. Go to the System Manager Dashboard page
  2. Hover over the desired node to check the serial number
Command Line
  1. For cluster wide serial numbers, run  System Controller Show  from the command line
a.For a more detailed view of an individual node, run system node show -node <node name> from the command line
::> system controller show
Controller Name           System ID     Serial Number     Model    Status
NetAppA                  5xxxxxxxx     7xxxxxxxxxxx      AFF-A250 ok
NetAppB                  5xxxxxxxx     7xxxxxxxxxxx      AFF-A250 ok
::> node show -node NetAppB
                                              Node: NetAppB
                                             Owner: NetAppuser
                                             Model: AFF-A250
                                     Serial Number: 7xxxxxxxxxxx
                                         Asset Tag: -
                                            Uptime: 413 days 21:50
                                   NVRAM System ID: 5xxxxxxxx
                                         System ID: 05xxxxxxxx
                                            Vendor: NetApp
                                            Health: true
                                       Eligibility: true
                           Differentiated Services: false
                               All-Flash Optimized: true
                                Capacity Optimized: false
                                     QLC Optimized: false
                        All-Flash Select Optimized: false
                     SAS2/SAS3 Mixed Stack Support: none
2. From the sysconfig -a, we can see the below information:
 NetApp Release 9.10.1P12D8: Thu Nov 23 19:10:13 EST 2023
 System ID: 053xx48804 (scc09n14a); partner ID: 0537xx8813 (sccxx14b)
 System Serial Number: 721xx00001x8 (scc09n14a)  >>>>>>>>>>>>>>>>>>>>>>>>  SSN
 System Rev: A4
 System Storage Configuration: Multi-Path HA
 System ACP Connectivity: Inband Active
 SAS2/SAS3 Mixed Stack Support: all
 All SAN Array: false
 Backplane Part Number: 111-0xx95
 Backplane Rev: A4
 Backplane Serial Number: 0218xx033849
 slot 0: System Board 1.7 GHz (System Board XXII B2)
                Model Name:         AFF-A300
                Part Number:        111-02493
                Revision:           B2
                Serial Number:      02182xx152x1   >>>>>>>>>>>>>>>>>  Board SN
                BIOS version:       11.20
                Loader version:     6.0.17
