NetApp Knowledge Base
Health alert shows "Storage shelf is not connected to both controllers of the HA pair"
1,082
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • DS460C
Issue
  • Health alter shows Storage shelf is not connected to both controllers of the HA pair
Cluster::> system health alert show
               Node: node A
           Resource: Shelf 8.12
           Severity: Major
    Indication Time: Wed Jun 10 16:46:33 2020
           Suppress: false
        Acknowledge: false
     Probable Cause: Storage shelf 8.12 is not connected to both
                     controllers of the HA pair (node A, node B).
    Possible Effect: Access to shelf 8.12 will be lost with a single
                     controller failure.
Corrective Actions: 1. Halt all controllers that are connected to shelf 8.12.
                     2. Connect shelf 8.12 to both HA controllers following the guide applicable to your shelf.
                     3. Reboot the halted controllers.
  • There is IOM showing FAIL in storage show fault:
Drawers Control Module:
Element Status Status Bytes Status Descriptions
1 [IOM12 A] : CRITICAL 02,40,00,00 FAIL
2 [IOM12 A] : OK 01,00,01,00 REPORT
3 [IOM12 A] : OK 01,00,01,00 REPORT
4 [IOM12 A] : OK 01,00,01,00 REPORT
5 [IOM12 A] : OK 01,00,01,00 REPORT
6 [IOM12 B] : OK 01,00,01,00 REPORT
7 [IOM12 B] : OK 01,00,01,00 REPORT
8 [IOM12 B] : OK 01,00,01,00 REPORT
9 [IOM12 B] : OK 01,00,01,00 REPORT
10 [IOM12 B] : OK 01,00,01,00 REPORT
New to NetApp?
