NetApp Knowledge Base
Health Monitor Reports "Redundant configuration is missing for cluster switches."
484
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • All FAS systems
  • Switched cluster configurations
Issue
Health alerts are generated reporting "Redundant configuration is missing for cluster switches."
::> system health alert show -alert-id ClusterSwitchMissing_Alert -instance
                      Node: node1
                   Monitor: cluster-switch
                  Alert ID: ClusterSwitchMissing_Alert
         Alerting Resource: cluster1-02
                 Subsystem: Switch-Health
           Indication Time: Wed Nov 27 10:22:08 2019
        Perceived Severity: Major
            Probable Cause: Configuration_error
               Description: Redundant configuration is missing for cluster switches.
        Corrective Actions:
                         1) Ensure that a redundant pair of cluster switches exists in the network.
                         2) Ensure that cluster ports are connected to both switches.
                         3) Enable the Cisco Discovery Protocol (CDP)/Industy Standard Discovery Protocol(ISDP)
                         on switches, if you previously disabled it. CDP/ISDP is enabled by default.
                         Refer to your switch documentation for instructions.
                         4) If Data ONTAP cannot automatically discover a switch, use the "system cluster-switch create"
                         command to configure discovery and monitoring of the switch.
New to NetApp?
