FAS9000 or AFF A700 boots successfully or unsuccessfully with unsupported NVRAM DIMM messages
Applies to
- FAS9000
- AFF A700
- ONTAP 9.1 and later
Issue
- Either node boots up successfully but with the following message:
[nvram.hw.initFail:CRITICAL]: NVRAM hardware initialization failed: DIMM0 has unsupported 2 rank DIMM 32 GB. Replace the NV-DIMM.
- Or node fails to boot and halts at LOADER prompt with following message:
[localhost:nv.none:EMERGENCY]: No NV device has been detected.
Uptime: 2m16s
System halting...
