NetApp Knowledge Base
The NVRAM battery capacity is critically low (0 cycles) warning on FAS9000/AFF-A700
1,266
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • AFF A700 / FAS9000
  • Service Processor (SP) firmware below 4.9
Issue
The NVRAM battery capacity is critically low (0 cycles) warning and recover soon.
Example:
Sun Sep 06 00:00:31 CST [host1: env_mgr: nvram.battery.capacity.low.critical:EMERGENCY]: The NVRAM battery capacity is critically low (0 cycles). To prevent data loss, the system will shut down in 5 minutes.
Sun Sep 06 00:01:12 CST [host1: env_mgr: nvram.battery.capacity.normal:info]: The NVRAM battery capacity is normal.
Sun Sep 06 00:01:32 CST [host1: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (capacity low) CRITICAL.
New to NetApp?
