NetApp Knowledge Base
FAS2552 or FAS2554 Ignoring unsupported device boot_i attached to the default bootdevice port
1,048
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • ONTAP 9
  • FAS2552
  • FAS2554
  • X1425A-R6 (firmware rev 141031)
  • SP1425D-R6 (Alternative Part Number)
Issue
  • Boot sequence with boot device P/N X1425A-R6 example:
IPsec: Initialized Security Association Processing.
Ignoring unsupported device boot_i attached to the default bootdevice port.
Boot Loader version 4.3
Copyright (C) 2000-2003 Broadcom Corporation.
Portions Copyright (C) 2002-2014 NetApp, Inc. All Rights Reserved.
CPU Type: Intel(R) Xeon(R) CPU C3528 @ 1.73GHz
Starting AUTOBOOT press Ctrl-C to abort...
File not found (errcode=-18)
diskinfo: /dev/da0: No such file or directory
ERROR: Unable to read diskinfo from device /dev/da0.
umount: /mnt: not a file system root directory
  • Same issue with any other boot device with the same firmware revision, including any additional replacement done.
  • Any attempt to restore the image file to a boot device using netboot fails. Example:
What is the URL for the package?
http://192.168.0.2/95P7_q_nodar_image.tgz
What is the user name on "192.168.0.2", if any?
Checking network link... success.
Checking route to host "192.168.0.2"... success.
Attempting to reach 192.168.0.2... success.
Looking up URL "http://192.168.0.2/95P7_q_nodar_image.tgz"... success.
Computed package size is 1461M Using ramdisk size of 1461M
Downloading package... success.
Checking package contents... success.
Extracting install script from package... success.
Invoking script (validation phase).
INSTALL running in check-only mode: the image will be validated only
Mode of operation is INSTALL Current image is image1
Alternate image is image2 Using device /dev/da0 for install
Package MD5 checksums pass Versions are compatible
Install Validation Failed. diskinfo: /dev/da0:
No such file or directory ERROR: Unable to read diskinfo from device /dev/da0. umount: /mnt: not a file system root directory
New to NetApp?
