NetApp Knowledge Base
Error joining node to existing cluster 'Cluster applications failed to initialize'
1,202
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
ONTAP 9
Issue
Unable to join node to existing cluster
Joining cluster ..............Error: Cluster applications failed to initialize due to internal communication problems. Run the setup wizard again to resolve the problem. Contact support personnel if the problem persists.
When adding nodes to a new cluster, first node joins without issue
Cluster::> cluster show
Node                 Health  Eligibility
Node-01           true    true
Node-02           true    true
Node-03           true    true
Node-05           false   true
New to NetApp?
