NetApp Knowledge Base
Disk shelf DS2246 is reporting UNDER-TEMPERATURE (UT) warning alerts
1,456
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
Applies to
  • DS2246
Issue
  • Disk shelf DS2246 reports UT WARNING alerts and after a while the warning gets auto corrected.
[FAS-01: statd: monitor.shelf.warning:warning]: Fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
[FAS-01: monitor.shelf.fault.ok:info]: Fault previously reported on disk storage shelf attached to channel 0a has been corrected.
[FAS-01: monitor: monitor.globalStatus.ok:info]: The system's global status is normal.
Temperature Sensors:
Element Status         Status Bytes  Status Descriptions
  1: NONCRITICAL       03,00,18,01   UT WARNING
  2: OK                01,00,24,00
  3: OK                01,00,2A,00
  4: OK                01,00,3D,00
  5: OK                01,00,28,00
  6: OK                01,00,3D,00
  7: OK                01,00,2B,00
  8: OK                01,00,2A,00
  • Though the temperature in the Data Center is normal, the warning is generated daily and goes back to normal state after some time.
New to NetApp?
