NetApp Knowledge Base
Controller attention LED on with set by SP
1,456
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8040
  • FAS8020
  • Service Processor (SP)
Issue
  • Controller attention LED on.
  • Set by SP can be found in the following command output.
ONTAP Cluster mode
Example:
cluster::*> system controller fru led show
Node                  FRU Type    Bay Slot State   Lit By
cluster-01
                      controller  A   1    off     -
                      pci         -   1    off     -
                      pci         -   2    off     -
                      pci         -   3    off     -
                      pci         -   4    off     -
                      batt-nv     -   1    off     -
                      boot        -   1    off     -
                      dimm-nv     -   1    off     -
                      dimm        -   1    off     -
                      dimm        -   2    off     -
                      dimm        -   3    off     -
                      dimm        -   4    off     -
cluster-02
                      controller  B   1    on      SP
                      pci         -   1    off     -
                      pci         -   2    off     -
                      pci         -   3    off     -
                      pci         -   4    off     -
                      batt-nv     -   1    off     -
                      boot        -   1    off     -
                      dimm-nv     -   1    off     -
                      dimm        -   1    off     -
                      dimm        -   2    off     -
                      dimm        -   3    off     -
                      dimm        -   4    off     -
Data ONTAP 8.2 7-mode
Example:
node*> fru_led status
Controller slot B: On (lit by SP)
DIMM slot 1:       Off
DIMM slot 2:       Off
DIMM slot 3:       Off
DIMM-NV slot 1:    Off
PCI slot 1:        Off
PCI slot 2:        Off
NV battery 1:      Off
Boot device 1:     Off
New to NetApp?
