Config Advisor alerts that the cluster switch configuration does not match the installed RCF
Applies to
- All Cisco, Broadcom, NVIDIA and NetApp-branded cluster interconnect switches:
- NetApp CN1610
- Broadcom BES-53248
- Cisco Nexus 5596UP/5596T
- Cisco Nexus 3132Q-V
- Cisco Nexus 3232C
- Cisco Nexus 92300YC
- Cisco Nexus 9336C-FX2
- NVIDIA SN2100
- NetApp Active IQ Config Advisor
Issue
After a new install or cluster interconnect switch hardware upgrade, Config Advisor alerts for a switch configuration that doesn't match the installed RCF. Example:
Rules Check Ars Signature: 3459
Description:
Configuration on the switch does not match to that of a Reference Configuration File (RCF) for NetApp Switch.
Severity:
Medium
Details;
Or
Configuration of switch does not match to that of the Reference Configuration File (RCF) for a Cisco Nexus Switches.
Or
Configuration check against RCF
Configuration of switch does not match to that of the Reference Configuration File (RCF) for a shared switch.
Differences found in: class-map HA
for interface Ethernet1/1 - priority-flow-control mode auto, switchport trunk allowed vlan 1,17,18, no lldp transmit, ... and 1 other
for interface Ethernet1/2 - priority-flow-control mode auto, switchport trunk allowed vlan 1,17,18, no lldp transmit, ... and 1 other
for interface Ethernet1/3 - priority-flow-control mode auto, switchport trunk allowed vlan 1,17,18, no lldp transmit, ... and 1 other
for interface Ethernet1/4 - priority-flow-control mode auto, switchport trunk allowed vlan 1,17,18, no lldp transmit, ... and 1 other and 16 others also has differences..
Configuration is not supported. Shared switch function may be impacted.
Switch model: NX9336C-FX2
RCF Filename : NX9336C-FX2-RCF-v1.12a-Shared.txt
