NetApp Knowledge Base
Can Cisco QSFP-4SFP10G-CU 40GbE to 10GbE breakout cables be used to connect a NetApp controller to a Cisco 40GbE data switch?
2,082
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS/AFF Systems
  • Cisco Switches
Answer
Customers might need to connect their Cisco 40GbE Ethernet switch ports to NetApp FAS platforms onboard or optional NICs using a Cisco copper 4x10GbE breakout cable.
The authoritative source for cable compatibility information is the NetApp Hardware Universe. NetApp part number X66120-3 or X66120-5 can be used as a cross-reference.
Cisco part numbers for QSFP+ to 4xSFP+ copper break-out cables:
  • QSFP-4SFP10G-CU-1M
  • QSFP-4SFP10G-CU-3M (NetApp Part Number: X66120-3)
  • QSFP-4SFP10G-CU-5M (NetApp Part Number: X66120-5)
Additional Information
additionalInformation_text
