NetApp Knowledge Base
Both PSUs showing MULTIFAULT
1,218
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • AFF A220 / FAS27x0
  • AFF A200 / FAS26x0
Issue
  • Two PSUs of single node show fault:
Example:
Sensor Name              State          Current    Critical     Warning     Warning    Critical
                                        Reading       Low         Low         High       High
PSU2 FRU                                MULTIFAULT
PSU1 FRU                                MULTIFAULT
SP Status                               IPMI_HB_OK
mSATA Status                                OK
mSATA Pres                              PRESENT
  • The PSUs of partner node which uses the same PSUs are good:
Example:
PSU2 FRU                                  GOOD
PSU1 FRU                                  GOOD
mSATA Status                                OK
mSATA Pres                              PRESENT
New to NetApp?
