NetApp Knowledge Base
Aggregate failed after multiple missing disks in same drawer
1,337
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
Applies to
  • DS460C
  • Multiple Disk Failure / disks missing
Issue
  • Multidisk panic after reseating IOM A on DS460C
  • Aggregate appears failed due to missing disks for same shelf drawer. system node run -node node_name -command sysconfig -r example:
Aggregate aggr_n02_data01 (failed, raid_tec, partial) (block checksums)
  Plex /aggr_n02_data01/plex0 (offline, failed, inactive)
    RAID group /aggr_n02_data01/plex0/rg0 (partial, block checksums)
      RAID Disk	Device  	HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      tparity	FAILED  		N/A                        9324290/ -
      dparity 	9c.13.6 	9c    13  6   SA:A   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      parity  	9a.11.6 	9a    11  6   SA:B   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9c.12.6 	9c    12  6   SA:A   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9a.10.6 	9a    10  6   SA:B   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9a.10.30	9a    10  30  SA:B   0  FSAS  7200 9324290/19096145920 9342976/19134414848 (reconstruct stalled)
      data    	9c.13.7 	9c    13  7   SA:A   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9a.11.7 	9a    11  7   SA:B   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9c.12.7 	9c    12  7   SA:A   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9a.10.7 	9a    10  7   SA:B   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data	FAILED  		N/A                        9324290/ -
      data    	9c.13.8 	9c    13  8   SA:A   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9a.11.8 	9a    11  8   SA:B   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9c.12.8 	9c    12  8   SA:A   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9a.10.8 	9a    10  8   SA:B   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9c.13.9 	9c    13  9   SA:A   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9a.11.9 	9a    11  9   SA:B   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9c.12.9 	9c    12  9   SA:A   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9a.10.9 	9a    10  9   SA:B   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9c.13.10	9c    13  10  SA:A   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9a.11.10	9a    11  10  SA:B   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9c.12.10	9c    12  10  SA:A   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      data    	9a.10.10	9a    10  10  SA:B   0  FSAS  7200 9324290/19096145920 9342976/19134414848
      Raid group is missing 4 disks.
  • Existing issue with DCM over channel B in the shelf caused lack of paths to the disks in a single drawer during the reseat
Drawers Control Module:
Element Status                      Status Bytes  Status Descriptions
1 [IOM12 A]    : OK                01,00,01,00   REPORT
2 [IOM12 A]    : OK                01,00,01,00   REPORT
3 [IOM12 A]    : OK                01,00,01,00   REPORT
4 [IOM12 A]    : OK                01,00,01,00   REPORT
5 [IOM12 A]    : OK                01,00,01,00   REPORT
6 [IOM12 B]    : CRITICAL          02,40,00,00   FAIL
7 [IOM12 B]    : OK                01,00,01,00   REPORT
8 [IOM12 B]    : OK                01,00,01,00   REPORT
9 [IOM12 B]    : OK                01,00,01,00   REPORT
10 [IOM12 B]    : OK                01,00,01,00   REPORT
  • After reinserting IOM A, aggregate remains failed
::> storage aggregate show -fields state
aggregate       state
aggr_n01_data01 online
aggr_n01_data02 online
aggr_n01_data03 online
aggr_n01_root   online
aggr_n02_data01 failed
New to NetApp?
