AFF C190 reboots due to multiple PSU fans failed
Applies to
- AFF c190
- Ontap 9
Issue
- Node reboots with;
Record 282: Wed Aug 10 16:09:59.530000 2022 [ASUP.notice]: First notification email | (REBOOT (abnormal)) WARNING | Send failed
Record 283: Wed Aug 10 16:10:01.000000 2022 [IPMI.emergency]: env_mgr triggers OS halt:Multiple fans failed
Record 284: Wed Aug 10 16:12:37.000000 2022 [BMC.emergency]: System input power lost
- Reviewing
cluster1::> system node environment sensors show
output has missing sensor values when ran for the problem node.Node Sensor State Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi ---- --------------------- ------ ----------- -------- -------- ------- ------- mynode PSU2 Fan2 Speed not-available PSU2 Fan1 Fault OK PSU2 Fan1 Speed not-available PSU2 Curr normal 28000 mA - - - - PSU2 Temp normal 29 C 0 5 51 61 PSU2 Present PRESENT PSU1 Over Curr OK PSU1 Over Volt OK PSU1 Over Temp OK
