NetApp Knowledge Base
"storage show fault" shows a failed power supply in a disk shelf
6,011
Visibility:
Votes:
5
Category:
disk-shelves
Specialty:
hw
Last Updated:
Applies to
  • DS4246
  • Reseating a faulty power supply has not resolved this issue
Issue
::>node run -node <nodename> -command storage show fault
shows a failed power supply in a disk shelf.
Example:
Customer Problem Summary :
Enclosure Status: critical
Channel: 0c
Shelf: 34
Shelf Type: DS4246
Product Serial Number: SHJSGXXXXXXXXXX
Module Type: IOM6
Power Supplies:
Element Status Status Bytes Status Descriptions
1: CRITICAL 02,00,00,F0 OFF, RQSTED ON, FAIL
2: OK 01,00,00,20 RQSTED ON
3: NOT INSTALLED 05,00,00,20
4: OK 01,00,00,20 RQSTED ON
New to NetApp?
