NetApp Knowledge Base
What impact an ESXi upgrade have on running Ontap Select VMs?
484
Visibility:
Votes:
0
Category:
ontap-select
Specialty:
ontapselect
Last Updated:
Applies to
  • ONTAP Select
  • VMware ESXi
Answer
The expected behavior is depending on cluster deployment. Please contact VMware support or check VMware documentation for more information.
  • The procedure might be disruptive for single-node cluster as drivers and firmware updates are in play on a single ESXi host.
  • The procedure can be non-disruptive if using 2-node cluster (HA pair) with nodes running on different hosts. Upgrading first one ESXi host and then the other, should maintain availability of the HA pair.
Additional Information
N/A
