NetApp Knowledge Base
How to set up or modify AutoSupport in Data ONTAP 7-mode
6,417
Visibility:
Votes:
9
Category:
data-ontap-8
Specialty:
7dot
Last Updated:
Applies to
  • Data ONTAP 7-mode
  • AutoSupport
  • This article describes the procedure to set up AutoSupport on a NetApp storage system.
  • NOTE:
    • AutoSupport configuration must be done on each node in the cluster.
    • For 7-Mode systems, the full list of AutoSupport options can be found in the Data ONTAP user manual, or by typing options autosupport on the storage system's console.
      • Example (NOTE: Not the full list)
>options autosupport
autosupport.enable           on
autosupport.mailhost mailhost1,mailhost2,mailhost3,mailhost4,mailhost5
autosupport.to myname@gmx.net
autosupport.from postmaster
autosupport.doit TESTING
autosupport.noteto myblackberry@gmx.net
autosupport.support.transport https
  • The table below provides an overview of the most commonly used 7-Mode AutoSupport configuration options.
    AutoSupport Option Default Recommended
    autosupport.enable
    On
    On
    autosupport.performance_data.enable
    On
    On
    autosupport.nht_data.enable
    On
    On
    autosupport.support.enable
    On
    On
    HTTPS
    HTTPS (HTTP / SMTP options available)
    autosupport.support.proxy
    Empty (HTTP or HTTPS only)
    User-defined
    autosupport.content
    Complete
    Complete
    mailhost
    User-defined
    autosupport.to
    Empty list
    User-defined
    autosupport.from
    Postmaster@systemname
    User-defined
    autosupport.partner.to
    Empty list
    User-defined
    autosupport.noteto
    Empty list
    User-defined
New to NetApp?
