NetApp Knowledge Base
How to renew and configure SSL Certificates?
22,405
Visibility:
Votes:
20
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
ONTAP 9
  • SSL Certificate
  • System Manager
  • NAS
    • LDAP
  • BMC / SP
  • FabricPool
  • S3 ONTAP
  • Encryption
  • Active IQ Unified Manager
Follow this guide to help you locate the proper solution for your ONTAP SSL certificate issue or question.
Managing SSL
The SSL protocol improves the security of web access by using a digital certificate to establish an encrypted connection between a web server and a browser.
You can manage SSL for the cluster or a storage virtual machine (SVM) in the following ways:
  • Enabling SSL
  • Generating and installing a digital certificate and associating it with the cluster or SVM
  • Displaying the SSL configuration to see whether SSL has been enabled, and, if available, the SSL certificate name
  • Setting up firewall policies for the cluster or SVM, so that web access requests can go through
  • Defining which SSL versions can be used
  • Restricting access to only HTTPS requests for a web service
Additional Information
New to NetApp?
