NetApp Knowledge Base
How to open a non-technical case
20,517
Visibility:
Votes:
13
Category:
not set
Specialty:
csib
Last Updated:
Applies to
All NetApp Support Site users
  • This article describes how to create a non-technical support case when you require assistance with non-technical topics but not limited to:
    • NetApp Support Site (NSS) queries
    • Product Registration (owner, location, and contact updates) queries Support entitlement & licensing queries, such as capacity licensing, cloud license, cloud sync license, Expired License, ONTAP license, evaluation license
    • Deploy license manager lock id, deploy node locked
    • Expired entitlement, no support entitlement
    • Install base updates (hostname, system ID, group name, delivery and dispatch preferences)
    • Changing the site's name
Procedure
  1. Navigate to  Non Technical Feedback (no login required)
  2. Or login to NetApp Support Site
  3. Click on Cases & Parts, and Create Non-Technical Case
  4. Select a FEEDBACK CATEGORY
Note: The category options vary depending on whether you can login or not login
Login & Registration issues (sign-in not required) Account and Profile issues (Sign-in required)
NetApp Support Site NetApp Support Site
  1. Some categories may provide content to help resolve your question/ issue
    • If the issue is resolved, click Resolved
    • If not resolved, click Create Case
NetApp Support Site
  1. Fill in the required details that support your request, and click Submit
  2. A non-technical case is created and a pop-up will be shown with the case number
New to NetApp?
