AutoSupport Message: PWRFLT Power Supply messages
Applies to
- Data ONTAP 7 and earlier
- ONTAP 8
- ONTAP 9
Issue
Shelf fault SHLFLT: System Notification from Filer1 (SHELF POWER INTERRUPTED) WARNING
AutoSupport PWRFLT:System Notification from Filer1 (SHELF POWER INTERRUPTED) WARNING
[ses.status.psWarning:warning]: DS14-Mk2-AT shelf 1 on channel 2a power warning for Power supply 2: non-critical status; DC undervoltage fault. This module is on the rear side of the shelf, at the right.
[ses.status.psError:CRITICAL]: DS14-Mk2-AT shelf 1 on channel 2a power error for Power supply 2: critical status; power supply failed. This module is on the rear side of the shelf, at the right.
AutoSupport message: Shelf Power Interrupted
You might also see the following AutoSupport messages:
SHELF_FAULT
SHELF COOLING UNIT FAILED
FAN FAIL
