Adapter card on FAS9000, AFF A700, and AFF A900 are missing from sysconfig after replacement
Applies to
- ONTAP 9
- FAS9000
- AFF A700
- AFF A900
- FRU replacement ( NIC, SAS, or FC adapter)
Issue
After replacement of an adapter card (such as NIC, SAS, or FC adapter), ONTAP is unable to recognize the card. It no longer shows as present in the system.
- AutoSupport SYSCONFIG-AC output from before adapter card replacement (slot 1 is present):
sysconfig: slot 1 OK: X91440A: 40G high performance
sysconfig: slot 2 OK: X91143A: Qlogic EP8324 Quad-Port 16Gb FC/10GbE PCIe CNA
sysconfig: slot 3 OK: X92071A: PMC PM8072; PCI-E quad-port SAS (PM8072)
sysconfig: slot 4 OK: X91440A: 40G high performance
sysconfig: slot 5 OK: X92071A: PMC PM8072; PCI-E quad-port SAS (PM8072)
sysconfig: slot 6 OK: X93140A: NetApp NVRAM10
sysconfig: slot 6-1 OK: X9172A: Flash Cache, 4.0TB NVMe SSD
sysconfig: slot 6-2 OK: X9172A: Flash Cache, 4.0TB NVMe SSD
sysconfig: slot 7 OK: X92071A: PMC PM8072; PCI-E quad-port SAS (PM8072)
sysconfig: slot 8 OK: X91440A: 40G high performance
sysconfig: slot 9 OK: X92071A: PMC PM8072; PCI-E quad-port SAS (PM8072)
sysconfig: slot 10 OK: X91143A: Qlogic EP8324 Quad-Port 16Gb FC/10GbE PCIe CNA
sysconfig: slot 11 OK: X92071A: PMC PM8072; PCI-E quad-port SAS (PM8072)
sysconfig: No shelf configuration errors detected.
sysconfig: There are no configuration errors.
- AutoSupport SYSCONFIG-AC output from after adapter card replacement (slot 1 is missing):
